Other Parts Discussed in Thread: TPS65982
We are currently using a TI Config tool which produces a xxx_low_region.bin (~61kB) and a xxx_flash_image.bin (~193kB) based on our settings in the tool. Are either of these the data binaries required by the I2C update? If not, what is the preferred way to generate the I2C update’s required file(s)?
Our current method of configuring the TPS chip is to burn the xxx_flash_image.bin onto the TPS chip’s dedicated SPI flash via HW programmer. This has the added benefit of ensuring that all trace of previous TPS configuration is replaced with new configuration. Does I2C update methodology provide as wide sweeping of coverage, i.e., is there any chance that settings defined in our config tool would not be able to be changed via the I2C update?
