Other Parts Discussed in Thread: HD3SS2522, TUSB320, TPS25810, HD3SS3220, TPS25740, TPS25741
Hi, I want to know more USB charger IC type, Could you give some reference ?
(For Type C 5V , 3A and no use I2C control)
Thank you~~~
Are you looking for USB Type-C charging solution?
For 5V/3A type-C solution, you can refer to TPS25810, which is the most integrated 5V/3A device. If you are looking for more flexible 5V/3A Type-C solution, you can look at TUSB320/1. TI also have HD3SS2522 and HD3SS3220 with CC logic and SS mux integrated.
For USB-C PD solution, you can refer to TPS25740/A, TPS25741/A, TPS6598X, TPS25725, etc..
Patrick
Hi ~Patrick
Thank you for your reply.
If I want to do a type C power bank, what could I select USB charger IC ? (No I2C control)
