DS25CP104A - Internal pull-up or pull-down resistors inside Sxx/ADDRx/SCL/SDA pins ?
Guru 19785 points
Other Parts Discussed in Thread: DS25CP104A
Hello Team,
Please allow me to ask you about the internal circuit of Sxx/ADDRx/SCL/SDA pins. Do these pins have internal pull-up or pull-down resistors ? If there is what is the resistor value for each pins ?
I believe the device does not require pull-up or pull-down resistors, however, customer prefers to use the resistors and would like to make sure they can apply correct voltage to the pins.
Kawai
