SDI Interface- Input logic standards supported for cable driver
Other Parts Discussed in Thread: LMH0302
I am using SDI cable driver with part number LMH0302 interfacing with Altera's Arria V FPGA. Please let me know whether this IC supports differential inputs in  PCML logic standard since Arria V FPGA transceivers output only in PCML logic standard. Minimum output peak-peak voltage from FPGA is much greater than minimum peak-peak input voltage required at the driver and hence it looks like the driver can be directly interfaced with FPGA. But the driver datasheet doesn't specify the supported logic standards.
Thanks & Regards
Madhu Sharma K
