[ DP83849I ] Link Instability with Port Dependency
Other Parts Discussed in Thread: DP83849I, DP83848I
My customer has reported that the link unstability behavior after power cycle. Also, according customer, this behavior can be seen only on Port A.
* DP83849I
* The ports are connected to other equipment which has same DP83849I inside.
* Repeat power cycle. This means the system power is turned off, then turned on again.
* Check LED indicator for each port
* When failure mode occurred, LEDs for port A (#19(LINK), #20(SPEED), #21(ACT) are turned on instantly, then off.
* In this situation, link is not established.
* Other port (port B) does not show this failure behavior.
(The information from customer is limited at this moment, let me know if further information is needed.)
Can you help me to clarify the issue and identify root cause?
Ken
Related Link
DP83848I Link LED flashing @ 6Hz, Intermittent link.
e2e.ti.com/.../1205759
DP83849IV Link unstability
e2e.ti.com/.../
DP83849I Link unstability on Freescale K70
e2e.ti.com/.../334622
