TPS65983 register map and apex creek FW INTMASK register value
Other Parts Discussed in Thread: TPS65982
Hi Team,
Is TPS65983 register map the same as TPS65982?
If different, could you share me the one for TPS65983
If the same, may I know what is the value of IntMask1 in TPS65983 apex creek FW?
I ask because we found TPS65983 INT behavior strange and would I use TPS65982 I2C GUI to read IntMask1, found only "AttentionReceived" bit was set, which should not be correct for Alpine Ridge system
Sam
  • Hi Sam,
    The Host Interface guide has details about the register settings for TPS65983. It is different compared to TPS65982. So the Utilities GUI would not interpret the register values correctly.
    Please request access for TPS65983 GUI and other documents as shown below.
    Arun
