Other Parts Discussed in Thread: TMS320DM6467
We are currently working on a hardware board design project for an Industrial application.
The processor used in TMS320DM6467ZUTA. We are facing an issue with ethernet interface. The Etherner PHYceiver IC interfaced with processor is L-ET1011C2-C-D (Gigabit Ethernet PHYceiver from LSI).
The Etherner PHYceiver IC is configured by processor through MDIO interface.
We are able to read all Etherner PHYceiver IC registers correctly at MD clock frequency of 4.5 MHz. The Etherner PHYceiver IC is connected to RJ-45 port. When we are connecting cross over cable between our Processor board and the Test PC, we could notice LAN connected (speed 100 MBPS) on our Test PC.
We configured separate static IP address for Processor board and Test PC. When we try to ping, the ping is getting failed (Error message: "PING is Not Alive")
NOTE: The Processor board has same ethernet interface as there in TMS320DM6467 Eval board. The configuration of the Ethernet PHYceiver is taken care by the UBOOT code. We are able to see the Ethernet PHYceiver IC recognised by the UBOOT.
Request you to provide valuable suggestions to fix our issue.
Balaji S
