DP83867IR Port Mirroring
Guru 15520 points
Other Parts Discussed in Thread: DP83867IR
I have a question about DP83867IR Port mirroring.
On our customer's board, pattern of between DP83867IR and RJ45 will be crossed
and we want to mirroring the port.
So, we will going to configure boot strap pin LED_0 to be MODE3 as follow:
R(Hi) = 1kohm + 4.7kohm
R(Lo) = 330ohm + 2.2kohm
Q1.In this case, only port of MDI will be mirrored, is it correct?
Q2.And I understand as that polarity will be not inverted, is it correct?
best regards,
g.f.
