Other Parts Discussed in Thread: DP83867IS
Hi All,
We are using DP83867IS in one of our design for 1G operation.Can any one suggest us RJ45 with Integrated Magnetics part?
Noted Thank you for answering
Hi All,
We have used Wurth Electronics part no 7499111000 on one of our Evaluation Modules. Please note that DP83867 can work with different magnetics as well. You can select any magnetics that meets or exceeds the following electrical parameters.
Parameter |
TYP |
Unit |
Condition |
Turn Ratio |
1:1 |
± 2% |
Insertion Loss |
-1 |
dB |
1-100 MHz |
Return Loss |
-16 |
dB |
1-30 MHz |
-12 |
dB |
30-60 MHz |
-10 |
dB |
60-100 MHz |
Differential to Common Rejection Ratio |
-30 |
dB |
1-50 MHz |
-20 |
dB |
50-150 MHz |
Crosstalk |
-35 |
dB |
30 MHz |
-30 |
dB |
60 MHz |
Isolation |
1500 |
Vrms |
HPOT |
-Regards,
Aniruddha
