TPS65982 / HPD GPIO Configuration
Guru 29720 points
Other Parts Discussed in Thread: TPS65982
Hi Team,
The datasheet shows there is 4 pattern to select HPD GPIO Configuration.
I believe I should select "00" or "11" if my customer' s application is DFP_D only, but I coudn't decide which is the better selection.
May I have your advice?
Yaita / Japan disty
  • '11' = GPIO4 as HPD TX/RX will work in every application where HPD signal is tied directly to the GPIO4 pin.
    • It is enabled as an Output (HPD TX) when the TPS65982 enters the DisplayPort Alt. Mode as a DFP_D.
    • It is enabled as an Input (HPD RX) when the TPS65982 enters the DisplayPort Alt. Mode as a UFP_D.
    Since these two scenarios are mutually exclusive (a product cannot be a DFP_D and UFP_D at the same time), it will only work in one direction per plug event. If the application is configured as a DFP_D only, it will always operate as HPD TX.
