TUSB211 installation position
Other Parts Discussed in Thread: TUSB211
Hi All,
My customer tries to use TUS211-Q1 to improve the eye diagram. The datasheet shows that with 2m USB cable, the eye diagram can be improved. But the TUS211 EVM is after the 2m USB cable, but the real cases is that TUSB211 will be put on the PCB board, and 2m cable is after the TUSB211. does it make any different to the result?
I noticed that in some  PCIE repeater, the repeater is recommend to be more closer to the receive, the further to the transmitter to maximize the EQ ability of the redriver, is it also required to put more closer to the receiver for TUSB211?
Thank you very much if you can help to reply.
Best Regards
Charles Zhang
