USB 3.0 - TUSB7320IRKM
Is there a forum specifically geared to the TUSB7320IRKM USB 3.0 controller. We are having Linux driver issues (in an ARM environment) and would like to talk to someone about it. We keep getting resets on configuration. Below is a dmesg dump from our system. Let me know if there is help out there.
Thanks, Mark Loffredo
[    6.233531] usb usb2: usb wakeup-resume
[    6.233549] usb usb2: usb auto-resume
[    6.233567] hub 2-0:1.0: hub_resume
[    6.233593] hub 2-0:1.0: port 1: status 0203 change 0001
[    6.340423] hub 2-0:1.0: state 7 ports 2 chg 0002 evt 0000
[    6.340482] hub 2-0:1.0: port 1, status 0203, change 0000, 5.0 Gb/s
[    6.460601] usb 2-1: new SuperSpeed USB device number 2 using xhci_hcd
[    6.483353] usb 2-1: skipped 1 descriptor after endpoint
[    6.483376] usb 2-1: skipped 1 descriptor after endpoint
[    6.483740] usb 2-1: default language 0x0409
[    6.493096] usb 2-1: udev 2, busnum 2, minor = 129
[    6.493121] usb 2-1: New USB device found, idVendor=13fe, idProduct=5500
[    6.493142] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    6.493158] usb 2-1: Product: Patriot Memory
[    6.493174] usb 2-1: Manufacturer:
[    6.493190] usb 2-1: SerialNumber: 07015B57D4048100
[    6.496606] usb 2-1: usb_probe_device
[    6.496641] usb 2-1: configuration #1 chosen from 1 choice
[    6.497437] usb 2-1: Successful Endpoint Configure command
[    6.499487] usb 2-1: adding 2-1:1.0 (config #1, interface 0)
[    6.501008] usb-storage 2-1:1.0: usb_probe_interface
[    6.501062] usb-storage 2-1:1.0: usb_probe_interface - got id
[    6.501093] usb-storage 2-1:1.0: USB Mass Storage device detected
[    6.502775] scsi0 : usb-storage 2-1:1.0
[    6.506893] imx-wm8962 sound.20: failed to find codec platform device
[    6.506938] imx-wm8962: probe of sound.20 failed with error -22
[    7.453090] fec 2188000.ethernet eth0: Freescale FEC PHY driver [Generic PHY] (mii_bus:phy_addr=fixed-0:00, irq=-1)
[    7.453199] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[    7.501337] scsi 0:0:0:0: Direct-Access              Patriot Memory   PMAP PQ: 0 ANSI: 6
[    7.884489] sd 0:0:0:0: [sda] 15482880 512-byte logical blocks: (7.92 GB/7.38 GiB)
[    7.885359] sd 0:0:0:0: [sda] Write Protect is off
[    7.885372] sd 0:0:0:0: [sda] Mode Sense: 23 00 00 00
[    7.886237] sd 0:0:0:0: [sda] No Caching mode page found
[    7.886245] sd 0:0:0:0: [sda] Assuming drive cache: write through
[    7.889458] sd 0:0:0:0: [sda] No Caching mode page found
[    7.889467] sd 0:0:0:0: [sda] Assuming drive cache: write through
[    7.889907] quirk3
[    8.000579] usb 2-1: reset SuperSpeed USB device number 2 using xhci_hcd
[    8.022837] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb000
[    8.022852] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb02c
[    8.023234] usb 2-1: Successful Endpoint Configure command
[    8.040883] quirk3
[    8.047859] svc: failed to register lockdv1 RPC service (errno 97).
[    8.048215] NFSD: Using /var/lib/nfs/v4recovery as the NFSv4 state recovery directory
[    8.048706] NFSD: starting 90-second grace period (net 8077f680)
[    8.160818] usb 2-1: reset SuperSpeed USB device number 2 using xhci_hcd
[    8.182937] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb000
[    8.182948] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb02c
[    8.183414] usb 2-1: Successful Endpoint Configure command
[    8.200743] quirk3
[    8.320674] usb 2-1: reset SuperSpeed USB device number 2 using xhci_hcd
[    8.342822] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb000
[    8.342834] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb02c
[    8.343211] usb 2-1: Successful Endpoint Configure command
[    8.360726] quirk3
[    8.481498] usb 2-1: reset SuperSpeed USB device number 2 using xhci_hcd
[    8.503006] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb000
[    8.503017] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb02c
[    8.503847] usb 2-1: Successful Endpoint Configure command
[    8.520707] quirk3
[    8.640634] usb 2-1: reset SuperSpeed USB device number 2 using xhci_hcd
[    8.662739] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb000
[    8.662752] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb02c
[    8.663219] usb 2-1: Successful Endpoint Configure command
[    8.680680] quirk3
[    8.800603] usb 2-1: reset SuperSpeed USB device number 2 using xhci_hcd
[    8.822898] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb000
[    8.822921] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb02c
[    8.823430] usb 2-1: Successful Endpoint Configure command
[    8.824420] sd 0:0:0:0: [sda] Unhandled error code
[    8.824439] sd 0:0:0:0: [sda]
[    8.824455] Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK
[    8.824471] sd 0:0:0:0: [sda] CDB:
[    8.824481] Read(10): 28 00 00 00 00 00 00 00 08 00
[    8.824551] end_request: I/O error, dev sda, sector 0
[    8.824570] Buffer I/O error on device sda, logical block 0
[    8.825063] quirk3
[    8.940612] usb 2-1: reset SuperSpeed USB device number 2 using xhci_hcd
[    8.962861] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb000
[    8.962886] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb02c
[    8.963391] usb 2-1: Successful Endpoint Configure command
[    8.980755] quirk3
[    9.100714] usb 2-1: reset SuperSpeed USB device number 2 using xhci_hcd
[    9.122961] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb000
[    9.122984] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb02c
[    9.123846] usb 2-1: Successful Endpoint Configure command
[    9.140758] quirk3
[    9.260693] usb 2-1: reset SuperSpeed USB device number 2 using xhci_hcd
[    9.282822] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb000
[    9.282849] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb02c
[    9.283380] usb 2-1: Successful Endpoint Configure command
[    9.300770] quirk3
[    9.420751] usb 2-1: reset SuperSpeed USB device number 2 using xhci_hcd
[    9.442919] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb000
[    9.442945] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb02c
[    9.443490] usb 2-1: Successful Endpoint Configure command
[    9.450781] libphy: fixed-0:00 - Link is Up - 1000/Full
[    9.450822] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[    9.461166]  sda: unable to read partition table
[    9.465038] sd 0:0:0:0: [sda] No Caching mode page found
[    9.465063] sd 0:0:0:0: [sda] Assuming drive cache: write through
[    9.465087] sd 0:0:0:0: [sda] Attached SCSI removable disk
[    9.486774] quirk3
[    9.600775] usb 2-1: reset SuperSpeed USB device number 2 using xhci_hcd
[    9.622914] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb000
[    9.622937] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb02c
[    9.623935] usb 2-1: Successful Endpoint Configure command
[    9.640781] quirk3
[    9.760750] usb 2-1: reset SuperSpeed USB device number 2 using xhci_hcd
[    9.782898] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb000
[    9.782924] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb02c
[    9.783460] usb 2-1: Successful Endpoint Configure command
[    9.800784] quirk3
[    9.920740] usb 2-1: reset SuperSpeed USB device number 2 using xhci_hcd
[    9.942926] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb000
[    9.942952] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb02c
[    9.943511] usb 2-1: Successful Endpoint Configure command
[    9.960755] quirk3
[   10.082206] usb 2-1: reset SuperSpeed USB device number 2 using xhci_hcd
[   10.102838] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb000
[   10.102864] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb02c
[   10.103769] usb 2-1: Successful Endpoint Configure command
[   10.120811] quirk3
[   10.240676] usb 2-1: reset SuperSpeed USB device number 2 using xhci_hcd
[   10.263058] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb000
[   10.263082] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb02c
[   10.263702] usb 2-1: Successful Endpoint Configure command
[   10.280789] quirk3
[   10.400660] usb 2-1: reset SuperSpeed USB device number 2 using xhci_hcd
[   10.423027] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb000
[   10.423050] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb02c
[   10.423597] usb 2-1: Successful Endpoint Configure command
[   10.424561] sd 0:0:0:0: [sda] Unhandled error code
[   10.424581] sd 0:0:0:0: [sda]
[   10.424594] Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK
[   10.424609] sd 0:0:0:0: [sda] CDB:
[   10.424619] Read(10): 28 00 00 ec 3f f0 00 00 08 00
[   10.424690] end_request: I/O error, dev sda, sector 15482864
[   10.424710] Buffer I/O error on device sda, logical block 1935358
[   10.425268] quirk3
[   10.540756] usb 2-1: reset SuperSpeed USB device number 2 using xhci_hcd
[   10.562899] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb000
[   10.562924] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb02c
[   10.563053] usb 2-1: Successful Endpoint Configure command
[   10.580767] quirk3
[   10.700589] usb 2-1: reset SuperSpeed USB device number 2 using xhci_hcd
[   10.722995] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb000
[   10.723020] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb02c
[   10.723147] usb 2-1: Successful Endpoint Configure command
[   10.740786] quirk3
[   10.860709] usb 2-1: reset SuperSpeed USB device number 2 using xhci_hcd
[   10.882843] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb000
[   10.882867] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb02c
[   10.882991] usb 2-1: Successful Endpoint Configure command
[   10.900765] quirk3
[   11.020766] usb 2-1: reset SuperSpeed USB device number 2 using xhci_hcd
[   11.042834] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb000
[   11.042862] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb02c
[   11.042998] usb 2-1: Successful Endpoint Configure command
[   11.060764] quirk3
[   11.181759] usb 2-1: reset SuperSpeed USB device number 2 using xhci_hcd
[   11.202756] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb000
[   11.202768] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb02c
[   11.202844] usb 2-1: Successful Endpoint Configure command
[   11.220705] quirk3
[   11.340606] usb 2-1: reset SuperSpeed USB device number 2 using xhci_hcd
[   11.362736] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb000
[   11.362751] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb02c
[   11.362824] usb 2-1: Successful Endpoint Configure command
[   11.363757] sd 0:0:0:0: [sda] Unhandled error code
[   11.363766] sd 0:0:0:0: [sda]
[   11.363770] Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK
[   11.363777] sd 0:0:0:0: [sda] CDB:
[   11.363783] Read(10): 28 00 00 ec 3f f0 00 00 08 00
[   11.363814] end_request: I/O error, dev sda, sector 15482864
[   11.363822] Buffer I/O error on device sda, logical block 1935358
[   13.677794] quirk3
[   13.790671] usb 2-1: reset SuperSpeed USB device number 2 using xhci_hcd
[   13.812925] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb000
[   13.812950] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb02c
[   13.813081] usb 2-1: Successful Endpoint Configure command
[   13.830753] quirk3
[   13.950652] usb 2-1: reset SuperSpeed USB device number 2 using xhci_hcd
[   13.972902] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb000
[   13.972927] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb02c
[   13.973048] usb 2-1: Successful Endpoint Configure command
[   13.990764] quirk3
[   14.110623] usb 2-1: reset SuperSpeed USB device number 2 using xhci_hcd
[   14.132879] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb000
[   14.132905] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb02c
[   14.133019] usb 2-1: Successful Endpoint Configure command
[   14.150787] quirk3
[   14.270615] usb 2-1: reset SuperSpeed USB device number 2 using xhci_hcd
[   14.292862] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb000
[   14.292889] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb02c
[   14.293036] usb 2-1: Successful Endpoint Configure command
[   14.310731] quirk3
[   14.440542] usb 2-1: reset SuperSpeed USB device number 2 using xhci_hcd
[   14.462797] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb000
[   14.462808] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb02c
[   14.462886] usb 2-1: Successful Endpoint Configure command
[   14.480714] quirk3
[   14.600693] usb 2-1: reset SuperSpeed USB device number 2 using xhci_hcd
[   14.622940] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb000
[   14.622964] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb02c
[   14.623098] usb 2-1: Successful Endpoint Configure command
[   14.624101] sd 0:0:0:0: [sda] Unhandled error code
[   14.624120] sd 0:0:0:0: [sda]
[   14.624132] Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK
[   14.624147] sd 0:0:0:0: [sda] CDB:
[   14.624160] Read(10): 28 00 00 00 00 00 00 00 08 00
[   14.624229] end_request: I/O error, dev sda, sector 0
[   14.624247] Buffer I/O error on device sda, logical block 0
[   14.624789] quirk3
[   14.740670] usb 2-1: reset SuperSpeed USB device number 2 using xhci_hcd
[   14.762942] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb000
[   14.762968] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb02c
[   14.763115] usb 2-1: Successful Endpoint Configure command
[   14.780753] quirk3
[   14.900643] usb 2-1: reset SuperSpeed USB device number 2 using xhci_hcd
[   14.922894] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb000
[   14.922919] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb02c
[   14.923045] usb 2-1: Successful Endpoint Configure command
[   14.940759] quirk3
[   15.060624] usb 2-1: reset SuperSpeed USB device number 2 using xhci_hcd
[   15.082872] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb000
[   15.082898] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb02c
[   15.083025] usb 2-1: Successful Endpoint Configure command
[   15.100744] quirk3
[   15.220790] usb 2-1: reset SuperSpeed USB device number 2 using xhci_hcd
[   15.242860] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb000
[   15.242883] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb02c
[   15.243003] usb 2-1: Successful Endpoint Configure command
[   15.260751] quirk3
[   15.380703] usb 2-1: reset SuperSpeed USB device number 2 using xhci_hcd
[   15.402830] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb000
[   15.402856] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb02c
[   15.402988] usb 2-1: Successful Endpoint Configure command
[   15.420838] quirk3
[   15.540669] usb 2-1: reset SuperSpeed USB device number 2 using xhci_hcd
[   15.562939] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb000
[   15.562964] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb02c
[   15.563088] usb 2-1: Successful Endpoint Configure command
[   15.564082] sd 0:0:0:0: [sda] Unhandled error code
[   15.564102] sd 0:0:0:0: [sda]
[   15.564115] Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK
[   15.564134] sd 0:0:0:0: [sda] CDB:
[   15.564142] Read(10): 28 00 00 00 00 00 00 00 08 00
[   15.564210] end_request: I/O error, dev sda, sector 0
[   15.564229] Buffer I/O error on device sda, logical block 0
[   15.564795] quirk3
[   15.680660] usb 2-1: reset SuperSpeed USB device number 2 using xhci_hcd
[   15.702914] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb000
[   15.702937] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb02c
[   15.703068] usb 2-1: Successful Endpoint Configure command
[   15.720848] quirk3
[   15.840637] usb 2-1: reset SuperSpeed USB device number 2 using xhci_hcd
[   15.862887] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb000
[   15.862911] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb02c
[   15.863043] usb 2-1: Successful Endpoint Configure command
[   15.880767] quirk3
[   16.000594] usb 2-1: reset SuperSpeed USB device number 2 using xhci_hcd
[   16.022988] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb000
[   16.023015] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb02c
[   16.023141] usb 2-1: Successful Endpoint Configure command
[   16.040743] quirk3
[   16.160722] usb 2-1: reset SuperSpeed USB device number 2 using xhci_hcd
[   16.182842] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb000
[   16.182867] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb02c
[   16.183015] usb 2-1: Successful Endpoint Configure command
[   16.200732] quirk3
[   16.320766] usb 2-1: reset SuperSpeed USB device number 2 using xhci_hcd
[   16.342817] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb000
[   16.342839] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb02c
[   16.342967] usb 2-1: Successful Endpoint Configure command
[   16.360757] quirk3
[   16.480673] usb 2-1: reset SuperSpeed USB device number 2 using xhci_hcd
[   16.502926] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb000
[   16.502951] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb02c
[   16.503080] usb 2-1: Successful Endpoint Configure command
[   16.504080] sd 0:0:0:0: [sda] Unhandled error code
[   16.504101] sd 0:0:0:0: [sda]
[   16.504114] Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK
[   16.504131] sd 0:0:0:0: [sda] CDB:
[   16.504140] Read(10): 28 00 00 00 00 00 00 00 08 00
[   16.504214] end_request: I/O error, dev sda, sector 0
[   16.504231] Buffer I/O error on device sda, logical block 0
[   99.120495] quirk3
[   99.240742] usb 2-1: reset SuperSpeed USB device number 2 using xhci_hcd
[   99.262867] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb000
[   99.262892] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb02c
[   99.263019] usb 2-1: Successful Endpoint Configure command
[   99.280748] quirk3
[   99.400715] usb 2-1: reset SuperSpeed USB device number 2 using xhci_hcd
[   99.422966] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb000
[   99.422991] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb02c
[   99.423117] usb 2-1: Successful Endpoint Configure command
[   99.440771] quirk3
[   99.560695] usb 2-1: reset SuperSpeed USB device number 2 using xhci_hcd
[   99.582820] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb000
[   99.582843] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb02c
[   99.582973] usb 2-1: Successful Endpoint Configure command
[   99.600758] quirk3
[   99.720791] usb 2-1: reset SuperSpeed USB device number 2 using xhci_hcd
[   99.742918] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb000
[   99.742941] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb02c
[   99.743066] usb 2-1: Successful Endpoint Configure command
[   99.760743] quirk3
[   99.880651] usb 2-1: reset SuperSpeed USB device number 2 using xhci_hcd
[   99.902898] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb000
[   99.902924] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb02c
[   99.903048] usb 2-1: Successful Endpoint Configure command
[   99.920851] quirk3
[  100.040614] usb 2-1: reset SuperSpeed USB device number 2 using xhci_hcd
[  100.062876] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb000
[  100.062899] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb02c
[  100.063030] usb 2-1: Successful Endpoint Configure command
[  100.064033] sd 0:0:0:0: [sda] Unhandled error code
[  100.064053] sd 0:0:0:0: [sda]
[  100.064065] Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK
[  100.064082] sd 0:0:0:0: [sda] CDB:
[  100.064095] Read(10): 28 00 00 00 00 00 00 00 08 00
[  100.064164] end_request: I/O error, dev sda, sector 0
[  100.064183] Buffer I/O error on device sda, logical block 0
[  100.064734] quirk3
[  100.180735] usb 2-1: reset SuperSpeed USB device number 2 using xhci_hcd
[  100.202860] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb000
[  100.202883] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb02c
[  100.203015] usb 2-1: Successful Endpoint Configure command
[  100.220850] quirk3
[  100.340713] usb 2-1: reset SuperSpeed USB device number 2 using xhci_hcd
[  100.362831] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb000
[  100.362855] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb02c
[  100.362982] usb 2-1: Successful Endpoint Configure command
[  100.380756] quirk3
[  100.500685] usb 2-1: reset SuperSpeed USB device number 2 using xhci_hcd
[  100.522939] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb000
[  100.522963] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb02c
[  100.523082] usb 2-1: Successful Endpoint Configure command
[  100.540742] quirk3
[  100.660669] usb 2-1: reset SuperSpeed USB device number 2 using xhci_hcd
[  100.682913] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb000
[  100.682936] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb02c
[  100.683075] usb 2-1: Successful Endpoint Configure command
[  100.700740] quirk3
[  100.820769] usb 2-1: reset SuperSpeed USB device number 2 using xhci_hcd
[  100.842889] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb000
[  100.842915] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb02c
[  100.843047] usb 2-1: Successful Endpoint Configure command
[  100.860762] quirk3
[  100.980593] usb 2-1: reset SuperSpeed USB device number 2 using xhci_hcd
[  101.002874] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb000
[  101.002897] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb02c
[  101.003028] usb 2-1: Successful Endpoint Configure command
[  101.004030] sd 0:0:0:0: [sda] Unhandled error code
[  101.004048] sd 0:0:0:0: [sda]
[  101.004062] Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK
[  101.004078] sd 0:0:0:0: [sda] CDB:
[  101.004091] Read(10): 28 00 00 00 00 00 00 00 08 00
[  101.004162] end_request: I/O error, dev sda, sector 0
[  101.004181] Buffer I/O error on device sda, logical block 0
[  101.004742] quirk3
[  101.120825] usb 2-1: reset SuperSpeed USB device number 2 using xhci_hcd
[  101.142848] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb000
[  101.142872] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb02c
[  101.142994] usb 2-1: Successful Endpoint Configure command
[  101.160746] quirk3
[  101.280705] usb 2-1: reset SuperSpeed USB device number 2 using xhci_hcd
[  101.302836] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb000
[  101.302860] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb02c
[  101.302990] usb 2-1: Successful Endpoint Configure command
[  101.320851] quirk3
[  101.440672] usb 2-1: reset SuperSpeed USB device number 2 using xhci_hcd
[  101.462808] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb000
[  101.462834] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb02c
[  101.462955] usb 2-1: Successful Endpoint Configure command
[  101.480721] quirk3
[  101.600655] usb 2-1: reset SuperSpeed USB device number 2 using xhci_hcd
[  101.622911] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb000
[  101.622936] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb02c
[  101.623070] usb 2-1: Successful Endpoint Configure command
[  101.640750] quirk3
[  101.760634] usb 2-1: reset SuperSpeed USB device number 2 using xhci_hcd
[  101.782894] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb000
[  101.782917] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb02c
[  101.783043] usb 2-1: Successful Endpoint Configure command
[  101.800766] quirk3
[  101.920742] usb 2-1: reset SuperSpeed USB device number 2 using xhci_hcd
[  101.942867] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb000
[  101.942891] xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep d89cb02c
[  101.943015] usb 2-1: Successful Endpoint Configure command
[  101.944017] sd 0:0:0:0: [sda] Unhandled error code
[  101.944036] sd 0:0:0:0: [sda]
[  101.944048] Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK
[  101.944065] sd 0:0:0:0: [sda] CDB:
[  101.944075] Read(10): 28 00 00 00 00 00 00 00 08 00
[  101.944144] end_request: I/O error, dev sda, sector 0
[  101.944163] Buffer I/O error on device sda, logical block 0
    Unfortunately we don't have control over the Linux driver for the xHCI, it was developed and is manged by the Linux community, you can contact Sarah Sharp from the Linux Community, are you using the latest kernel? Does the issue happens with other kernel versions?
