Other Parts Discussed in Thread: DP83848C
I'm laying out a PCB for the DP83848C (to an RJ-45 with internal magnetics). The Apps Note guidelines say "MDI signal traces should have 50 ohm to ground or 100 ohm differential controlled impedance". I understand the differential impedance being crucial, but am unclear about the single-ended - I can get a lay-up/spacing/etc for 100 diff, but the single-ended comes out at ~66ohm. Is this going to cause a problem?
Also, the Apps Notes say "trace lengths should be kept as short as possible" but other info I've read (albeit for different Phy's) suggest that >20mm or so is advisable?
