SN65DSI83, SN65DSI84, SN65DSI85 - sample code using I2C
Other Parts Discussed in Thread: SN65DSI84, SN65DSI85, SN65DSI83
Hi all
Would you mind if we ask SN65DSI83, SN65DSI84 and SN65DSI85?
Our customer are looking for sample code to set default using I2C.
Do you have anything to refer?(only Example Script on the datasheet?)
Kind regards,
Hirotaka Matsumoto
  • Hello Matsumoto-san,
    The DSI8x settings depend on the target panel capabilities, there is not a generic configuration. We suggest to use the DSI Tuner tool (available at www.ti.com/.../sllc434) to generate the registers settings based on the configuration they are planning to use, and then we can review it if they provide the *.dsi file which is generated with the tool along with the panel information.
