TUSB8020B GRSTz at Startup
Hi Team,
I have some questions about this sentence in the datasheet:
A minimum reset duration of 3 ms is required, which is defined as the time when the power supplies are in the
recommended operating range to the deassertion of GRSTz. This can be generated using programmable-delay
supervisory device or using an RC circuit.
I already found this here in the forums but it is a little bit unspecific in some therms:
Questions I still have:
  • Which supply rail is the internal pull-up connected to and approximately what is its value?
  •  Is there an internal voltage rail monitor that waits until both regulators are in regulation before allowing the capacitor to charge through the internal pull-up?
  •  What do you consider ramping “quickly” or “slower”?
Thank you for your time!
SF
