DS125BR800A - READ_EN# - tie low or pulse?
Other Parts Discussed in Thread: DS125BR800A
In Table 1 of the Datasheet, the READ_EN# pin is described as needing a high-to-low transition to start the load from the External EEPROM.   Later in the document - section on SMBUS Master Mode - the recommendation is to tie READEN# of the first device to GND.  Which is correct?
  • Hi Neil,
    A transition from high-to-low will allow you to start an External EEPROM load at the time of your choosing.
    However, if there is no reason to wait for a prior event to occur before loading the EEPROM after power is applied to the DS125BR800A, you can power-up the first DS125BR800A in your EEPROM programming daisy-chain with READEN# tied to GND.
    Michael
