TPS65982 with two-flash memery
Other Parts Discussed in Thread: TPS65982
Team,
Want to use two-flash memory(One for Host case, another is for device) with one-PD IC(TPS65982)
There will be SPI Mux(Switch) and mux will switch between two-flash images for each case(Host case and device case)
To load the appcode from flash memory, need hard-reset or soft-reset?
I am attaching simple block for that concept
Thank you
