Hi Ti guys:
Our commpany use the IC sn65DSI86,we can control it by i2c.But it doesn't transmit dsi to edp. Now how can I debug.We find the color bar function in spec,How can I use it?
Hi Ti guys:
Confirm that ASSR is enabled in your panel. Attached document has an example of how to enable ASSR.
After that, you have to program theVideo Registers based on your panel parameters and enable the COLOR_BAR_EN bit.
You can post the panel datasheet and we will check if we have a script to enable the color bar with that resolution.
I have upload the spec of TC358860XBG_TD_V18. Can you help me config it?
