TPS65982 Register Update Timing
Other Parts Discussed in Thread: TPS65982
Hi all,
My customer wants to know the time between Rp/Rd cable connection -> register update (source or sink) in TPS65982.
How long does it take for source or sink register updated after cable connection? I couldn't find it in the datasheet.
Sean Moon
  • Hi Sean,
    There is a debounce time that has to be met before a connection is determined (100ms). Once the connection is determined DFP or UFP it will update the register. If there is PD communication and a PD Power Role Swap is initiated the register will be updated as soon as the swap is completed.
    The timing can vary depending on the other operations on the device, such as I2C traffic. Is there a specific timing problem you customer is seeing?
    Jacob
  • Hi Jacob,
    Thanks for the reply
    The timing Sean is asking is the register update delay after TPS65982 determine it's role as DFP or UFP
    If there are some I2C register changing delay due to device internal property, could you share that delay range?
    And is there are timing variation with connecting with PD controller(Negotiate through CC line) and Rp/Rd connecting?
    No timing problem, however customer inquired to implement specific special function
    Thank you
