Failure condition of Dp83848i
Other Parts Discussed in Thread: DP83848I
Dear Sirs,
My customer asked me about  failure condition of DP83848i.
For example,
In the condition that the input information to the TXD port has caused a bit garbled by an internal failure of the IC, Do you have that information different from TD port as a failure mode is output?
Internal fault and is, for example,
Failure of the IC of the clock generation functions and register function in the page data sheet 27.
Because it is a problem the feed you want information would be replaced by different information.
Y.Hasebe
    TXD port is input to the PHY and driven by the processor. If there is a data error on the TXD port then the transmitting PHY will not be able to identify it. DP83848 has a receive error counter which increments when a error packet is received. So the error in trasmitting data will be detected at the receiving end.
    Re-transmitting corrupted packet is a higher layer application and needs to be implemented in the processor.
    -Regards,
    Aniruddha
  • Hello Aniruddha-san,
    Thank you for your quick reply.
    I understand your comment.
    I will tell my customer this comment.
    Y.Hasebe
