TPS65982EVM SPI flash programming with Aarvark
Other Parts Discussed in Thread: TPS65982
the information about programming FW into flash memory in TPS65982EVM documentation is somewhat confusing.
It is suggested to use Aardvark I2C for the programming.
Is it possible to use Aardvark SPI to program and customize the board?
thanks,
  • The Aardvark SPI programmer can be used to program the SPI flash of the TPS65982 EVM. The flash image for the EVM is generated using the TPS6598x Configuration Tool. The Aardvark does not plut directly on to the EVM. You will have to "fly wire" the Aardvark connector to the SPI pins of the EVM.
