need reference register settings for manual mode
Other Parts Discussed in Thread: DS125DF1610
I'd like to use TI's DS125DF1610 (16-ch retimer), and want to use this ic as no adaption mode.
Can you share the TI's recommanded register values for 10.3125 Gpbs at ADAPT_MODE 00?
for your information, reference clock is 25MHz, no cross point.
  • We typically only recommend adapt mode 0 for applications where the retimer pre-channel insertion loss is very low. For such a scenario, the settings below apply:
    REG
    Value
    Comment
    0x31
    0x00
    Set to Adapt mode 0
    0x2D
    0x88
    Enable EQ override
    0x03
    0x00
    Set EQ = 00
    0x3A
    0x00
    Set EQ = 00
    0x0A
    0x1C
    Puts the CDR into RESET
    0x0A
    0x10
    Releases the CDR from reset
    Rodrigo Natal
    DPS Applications Engineer
