TPS65983: PD certification
Did TPS65983 pass the PD certification? If user would like to pass the PD certification with his application, it requires attached platform information. Could you please help to support this?
; Vendor Info File Generator 1.0.0.1
;   Intro tab
$VIF_Specification: "Revision 0.54, Version 1.0"
$VIF_Producer: "USB-IF Vendor Info File Generator, Version 1.0.0.1"
UUT_Device_Type: ������
$Vendor_Name: ������
$Product_Name: ������
$Version_Info: ������
$TID: ������
$Port_Label: ������
;   General PD Settings tab
PD_Specification_Revision: ������
USB_Comms_Capable: ������
DR_Swap_To_DFP_Supported: ������
DR_Swap_To_UFP_Supported: ������
Externally_Powered: ������
VCONN_Swap_To_On_Supported: ������
VCONN_Swap_To_Off_Supported: ������
Responds_To_Discov_SOP: ������
Attempts_Discov_SOP: ������
SOP_Capable: ������
SOP_P_Capable: ������
SOP_PP_Capable: ������
SOP_P_Debug_Capable: ������
SOP_PP_Debug_Capable: ������
;   Source tab
PD_Power_as_Source: ������
USB_Suspend_May_Be_Cleared: ������
Sends_Pings: ������
Num_Src_PDOs: ������
    Src_PDO_Supply_Type1: ������
    Src_PDO_Peak_Current1:  ������
    Src_PDO_Voltage1:  ������
    Src_PDO_Max_Current1:  ������
;   USB Type-C tab
Type_C_State_Machine: ������
RP_Value: 2        ; ������
Type_C_Can_Act_As_Host: ������
Type_C_Can_Act_As_Device: ������
Type_C_Power_Source:  ������
Type_C_BC_1_2_Support:  ������
Type_C_Battery_Powered:�@������
Type_C_Port_On_Hub: ������
Type_C_Supports_Audio_Accessory: ������
Captive_Cable: ������
Type_C_Sources_Vconn: ������
Nagata.
