TPS25740 compability testing
Other Parts Discussed in Thread: TPS25740, TPS65982, TPS25740A
Hi :
  We are using TPS25740 as a power source product , now we are testing with TPS65982 EVM board with different setting, the output is OK, we also test the Apple adaptor(A1540) with TPS65982 EVM, the output is 14.5V when TPS65982 setting config ID #1,  but only can output 5V in others different config ID, So we are worried our product with TPS25740 only can output 5V/3A with other devices (like Macbook pro/Google Pixel), could you help to let us know did TI test the compability with different  PD function devices in the market ?
  • Hi
    Thank you for considering TI devices in your design, I wanted to bring to your attention that there is a section (Test Results) in the TPS25740 Evaluation Module users' guide content about testing, please find the link below:
    http://www.ti.com/lit/ug/slvuap7a/slvuap7a.pdf
    In this section you can find different tests conducted on TPS25740 with waveforms showing output voltage transitions 5-V, 12-V, and 20-V, also showing plugging/unplugging  MacBook as UFP, we are currently in the phase of testing market released products as few are available today.
    You can also order the TPS25740 Evaluation Module via the link below to do testing for your specific application.
    http://www.ti.com/tool/tps25740evm-741#buy
    Thank you again for considering TI devices and please do not hesitate to post any question or questions you may still have.
    Haidar
    Please consider checking the "Verify Answer" button if I've answered your question.
  • Hi Haidar:
    Thanks for your prompt reply, appreciate it.
    According the TPS25740 Evaluation Module users' guide, it can output 12V with MacBook even the Macbook's adaptor PD is 5V/14.5V
    We are worried if Macbook require 14.5V, TPS25740 setting is 5V/12/V/20V. it only can output 5V
    Anyway ,We will keep testing and let you know the result , please feel free to let us know how can I get if TI update the testing data with different PD devices ?
    Best regards
    Will
  • Hi
    Your are very welcome, I wanted also to bring to your attention that we have another device that might best fits you application needs which is the TPS25740A, this devcie uses the same Evaluation Module of the TPS25740 but the TPS24740A outputs 5V/9V/15V which is better suited for MacBook requirment of 14.5V. Please find link below for TPS25740A datasheet along with Evaluation Module :
    www.ti.com/.../tps25740a.pdf
    www.ti.com/.../slvuap7a.pdf
    Also updates to both TPS25740 and TPS25740A online datasheets and other TI USB Type-C PD devices will continue as new tests results become available. Thank you again for considering TI devices and please do not hesitate to post any question or questions you may still have.
    Haidar
  • Hi Haidar :
      Thanks for your information , we do check the TPS25740A and testing it since it's pin to pin of TPS25740.
    now we have the problem is our client want the product can support the all PD devices in the market with maximum power output, not just 5V/3A
    the below is the product list, it looks there is no a perfect solution for this ,right ?
    (1) If we choose the TPS25740A, it only support setting 5V/9V/15V , it means the 20V notebook can't support.
    (2) no matter TPS25740 or TPS25740A, according our support , if the notebook setting is 14.5V , it only output 5V
    Could you let's know any solution for this ?
    Manufacturer/Brand
    Product Name
    Product Type
    Output (W)
    Apple’s
    MacBook 13"
    Laptop
    61W USB-C Power Adapter
    MacBook 15"
    Laptop
    87W USB-C Power Adapter
    Google
    Chromebook Pixel
    Laptop
    USB-C can deliver up to 100W
    Pixel
    Phone
    USB Type-C 18W charger
    Nexus 5X
    Phone
    USB Type-C 15W (5V/3A) charger
    Pixel C
    Tablet
    15W USB Type-C Charger
    Nexus 6P
    Phone
    HTC
    One A9
    Phone
    10
    Phone
    Asus
    Zenfone 3 Deluxe
    Phone
    Output: 9V 2A 18W
    Zenfone 3 Ultra
    Phone
    Output: 9V 2A 18W
    Zenfone 3
    Phone
    Output: 5V 2A 10W
    ZenPad 3S 10 (Z500M)
    Tablet
    ZenPad 3 8.0 (Z581KL)
    Tablet
    Samsung
    Galaxy TabPro S
    Tablet
    Razer
    THE NEW RAZER BLADE STEALTH - QHD
    Laptop
    45W USB-C power adapter
    HP
    HP Spectre x2 Detachable Laptop - 12t touch
    Ultrabook
    45 W AC power adapter
  • Hi
    Sorry for the late reply, but I have forwarded your questions to our design, application, and system engineers to address them. We are currently working on releasing new devices targeting USB Type-C PD 5V-20V/ 5A in addition of supporting Alternative mode and this is all I can share with you up to this moment. As you mentioned with your question, you guys are testing with TI TPS65982EVM and device which also Supports USB Type-C PD but TPS65982 may not be cost-effective for your application and that's why we are working on newer inexpensive devices .
    As for TPS25740A not charging MacBook of 14.5V, could you please share more information about this issue so we can help with it?
    Again thank you for considering TI devices in your design and I will get back to you as soon as I hear back from our team.
    Haidar
  • Hi
    Just wanted to share with you that using TPS25740AEVM you can charge Chromebook C1501W laptop @15V/3A, so devices (sinks) with higher than 15V sinking capability (20V like the Chromebook) can be charged with a lower voltage using TPS25740A, again thank you for considering TI parts and please do not hesitate to post any question or question you may still have.
    Haidar
  • Hi Haidar :
      Thanks for your all support and information, we will keep updating about this issue.
    Best regards
    Will
