TPS2549 -Q1/ Cable compensation function
Other Parts Discussed in Thread: TPS2549-Q1
My customer is considering to use the TPS2549-Q1, I received the following question from them.
Is there any important of matter which it is not mentioned on the datasheet when using cable compensation function?
Kuramochi
  • Hi Kuramochi,
    Thank you for considering TI parts, TPS2549-Q1 datasheet has sufficient information regarding cable compensation function in Feature Description section where a detailed design procedure is explained, also in Application and Implementation section where additional design requirements and calculations are laid-out, again thank you for choosing TI parts and please do not hesitate to post any question or question you or your customer may have.
    Haidar
