[DP83867] Configuration for 1000M Ethernet compatible for 100M Ethercat
Other Parts Discussed in Thread: DP83867E
Hi Expert,
My customer is considering DP83867 in their system right now. They need DP83867 to be compatible for both 1000M Ethernet and 100M Ethercat.
1. Does DP83867 support both 2 modes with the same HW implementation? should we use RGMII mode?
2. For RJ45 connector, could DP83867 swap TD_P/M_A with TD_P/M_D(C/B) or other transmitting ports can be swapped with each other randomly if Auto_MDIX is enabled? Any rules between to connect TD_P/M_ABCD to RJ45 connector?
Thanks a lot.
Zhou
