TPS65982D Power connection
Other Parts Discussed in Thread: TPS65982D
If an external DC/DC is used to power the CPU which will be used to patch the TPS65982D, and also powers the TPS65982D's Vin_3V3, where should this buck be powered from?  Should it be powered from VBUS directly, or from the switched VBUS node.  Does BusPowerZ  need to start with the FETs engaged (i.e Grounded BusPowerZ pin) to avoid any glitches upon a soft-reboot of a personality patch?
