Other Parts Discussed in Thread: HD3SS460, TPS65982, TPS65986EVM, DP-EXPANSION-EVM
Hi TI members,
My customer is designing Tablet PC and evaluating his board that TPS65982+HD3SS460 is mounted.
He said USB3.0 flash memory was detected as USB2.0 (High speed) when "Type-C to Type-A receptacle cable" is used.
I tried to evaluate TPS65986EVM + DP-EXPANSION-EVM (the following constitution) to reproduce his issue and confirmed that same issue was occured.
I used iBUFFALO's Type-C to Type-A receptacle cable that supports USB3.1 in this case.
Just to tell you I set TPS65986EVM Configuration ID 1 (Notebook System) as the following.
Which register should I change to detect USB3.0 flash memory as USB3.0 (Super speed) correctly with "Type-C to Type-A receptacle cable"?
I can access TPS65986 registers with Aardvark, so I would like to know it.
Your prompt support is really appreciated because of my customer's design schedule.
Yaita / Japan disty
