LMH1218 - How to display eye open monitor (EOM) in error hit density mode.
Guru 19785 points
Hello Team,
Our customer is reading hits from register 0x25 and 0x26 to draw eye opening with their own software.
I am understanding that you could easily draw EOM in "figure 7" below, but, how can you draw EOM like figure 8 with user software (Not SigCon Architect) ?
Kawai
  • **Edited response**
    Hi Kawai-san,
    I realize that my initial response came under the assumption that you were using SigCon Architect, so I misunderstood the question. Please see corrected response below:
    Figure 7: Perform an EOM capture to obtain the raw hit count (just as you have suggested). Make everything above a certain threshold one color and everything else another color.
    Figure 8: To acquire an eye similar to Figure 8, you can perform a first-derivative of the original EOM data.To do this, perform an EOM capture, which results in a (64 phase step) x (64 voltage step) matrix of hit count values. From there, generate a 64 phase step by 63 voltage step matrix, where each value of the matrix is computed by taking the absolute value of the difference between a given hit count and the hit count of the adjacent voltage step. Make everything below a certain threshold (for example, less than 10) black, and everything above this threshold colored on a color scale.
    SigCon Architect automatically performs both the Error Hit Count (Figure 7) and Error Hit Density (Figure 8) described above.
    Michael
  • Hello Michael-san,
    Thank you for your reply. What I see above/below the crossing point is that error hit count is something like 3500.
    It is not a small number like ten to a few tens.
    I will send you the customer data via email, so could you please check ?
    Thanks in advance.
    Kawai
  • Hi Kawai-san,
    I believe if we take the first derivative of the resulting eye monitor output, we will be able to generate an eye density plot. Let's continue this discussion via e-mail.
    Michael
    Thank you for the information. I understood how SigCon builds the EOM in Error Hit Density mode.
    Kawai
