DS90UB914A-Q1 VID spec
Other Parts Discussed in Thread: DS90UB914A-Q1
I confirmed datasheet of DS90UB914A-Q1 to check VID spec.
There is description about min value of VID, however, there is no description about max value of VID.
So could you please tell me max value of VID ?
Machida
    There is no max VID spec on the 914A although there is a max VOD spec in datasheet on 913A. Since all 913A devices shipped in production will have max VOD or lower, keep in mind that input VID will be lower than max VOD due to cable loss, trace loss, connector loss, etc. We do not specify a max VID as there is no need when spec'ing max VOD on 913A. If the customer is having issues with short cables, there are things that can be done to fix this independent of VOD/VID spec.
    -Sean
