Other Parts Discussed in Thread: TCAN1042-Q1
I'd like to ask some questions about TCAN1042-Q1's CAN bus wake-up function.
- Is it correct to understand that three pulses (filtered dominant, followed by filtered recessive and filtered dominant) are required to acknowledge the wake request?
- Once an wake up pattern is recognized, will the RXD output go Low every time a filtered dominant is received?
- Once the TCAN1042-Q1 goes back to normal mode and then enters standby mode again, will the wake up monitor be reset and ready to receive three pulses (wake up pattern) again?
- Will the TCAN1042-Q1 NOT wake up by one pulse (only filtered dominant)? If the CAN transceiver MUST wake up by one pulse, can the TCAN1042-Q1 NOT be used?
Shinichi Yokota
