tps65982/d vconn power
Other Parts Discussed in Thread: TPS65982D, TPS65982
Hi
I saw type-c spec, vconn can be disable/enable after discovery identity. So I check the response data for discovery identity have a information about vconn disable in AMA VDO. so i suppose VCONN should be control by this bit.
But in tps65982 (1.11.5)and tps65982d(patch6), it seems do not check the bit to disable/enable for vconn power.
Can you help me to double check this function? or this is my misunderstand.
