Part Number: PCA9545A
Hi team,
My customer found that PCA9545A will output some random I2C command during power on, while the master didn't send any command.
Do you have any idea why it happened?
Thank you!
Hi team,
Thank you!
Two observations:
1) Your resolution on your waveform is very low. Can you obtain a higher resolution (time scale) waveform? It's difficult to see the waveform accurately.
2) The PCA9545A itself does not have any ability to pull-down on the clock line. It physically does not have any pull-down driver, so it is not possible that the PCA9545A itself is pulling down on the clock line.
However, it may be possible that you have communication on one of the down-stream channels which is getting through to the main bus at power up, but we would need to verify that (it should not happen).
Can you get a better waveform (with more time-scale resolution). Your time-scale is 100us per divison. As reference, you could very well be seeing aliasing from actual i2C communications.
