DP83867CS: DP83867CS PHY Address setting problem
Part Number: DP83867CS
If use SGMII mode,DP83867CS  PHY Addresscan be set to all 0?How many settings?
    DP83867CS has 4bits for PHY Address PHY_ADD[0:3] and all of them can be used in SGMII mode. This gives 16 possible address settings.
    Please note that the strap resistor value for mode 4 in SGMII operation are different, Rhi=4kohm and Rlow=10kohm. This is also recorded in the datasheet. For balanced loading in SGMII operation, RX_D1 should have same strap as RX_D0 and RX_D3 should have same strap as RX_D2.
    -Regards,
    Aniruddha
