SN65DPHY440SS: Asking for the MIPI redriver interface trace length
Part Number: SN65DPHY440SS
Other Parts Discussed in Thread: SN75DPHY440SS
Hi team,
Can you provide the comment for the following question?
for surveillance camera MIPI / CSI-2, how long the trace will need the MIPI redriver or retimer?
SHH
  • Table 15. Design Parameters
    PARAMETER VALUE
    Data Rate 1 Gbps
    Input trace length 12 inch
    Output trace length 1 inch
    Trace width 10 mils
    More information available in datasheet section 8.
    It will also the depend on interpair skews.
  • Hi Win,
    Customer PCB trace length is less than 15cm. the trace width is 3.5mil.
    Data rate is 1Gbps/lane.
    1. Does this <15cm application need the retimer?
    2. do TI have higher speed that can support >1Gpbs solution?
    3. for SN75DPHY440SS, what is the image sensor resolution that can support and data rate per lane?
    SHH
