DS110DF111: DS110DF111SQE/NOPB reference clock
Part Number: DS110DF111
Other Parts Discussed in Thread: DS110DF410, DS100MB203, DS125DF1610
I'm planning to use 4 pieces of DS110DF111SQE/NOPB in one board, as below.
Is it possible for me to connect DS110DF111SQE/NOPB's reference clock as a daisy chain?
  • Hi TS,
    Sorry for the delay in response. We will look into this and get back to you early next week.
    Michael
  • Hello TS,
    The DS110DF111 does not have a reference clock output so there isn’t a way to daisy chain the reference clock for this device.
    The DS110DF410 is a very similar device and does allow for daisy chaining of reference clocks. From the DS110DF410 data sheet:
    8.4.4.4 Reference Clock Out
    REFCLK_OUT pin 42 is the reference clock output pin. The DS110DF410 drives a buffered replica of the 25 MHz reference clock input on this output pin. If there are multiple DS110DF410 in the system, the REFCLK_OUT pin can be directly connected to the REFCLK_IN pin of another DS110DF410 in a daisy chain connection. The number of devices cascaded in a REF_CLK daisy chain is affected by the effective capacitance of the board trace connecting the REFCLK_OUT of one device to the REFCLK_IN of the next device. The pulse high duration at the input of the last device must be greater than 4ns for proper operation.
    In cases of cascading daisy chain with short trace (around 1.5 inches or 5pF trace capacitance), it is possible to cascade up to 9 devices. In other systems with longer interconnecting trace or more capacitive loading, the max number of daisy chained devices would be smaller. In a system which requires longer daisy chain, it is recommended to place an inverted gate after the 6th device. The pre-distorted duty cycle from the inverter allows for longer daisy chain. A better approach is to break the long daisy chain into two shorter chains, each driven by a buffer version of the clock and with each chain kept to a maximum of 6. As an example, if there are 12 devices in the system, the daisy chain connections can be divided into two groups of 6 devices and PCB trace length for the reference clock output to input connection should be 1.5 inch or less.
    Additionally, the DS110DF410 is a four channel device, so your design would only require two devices instead of four, and has slightly lower power consumption per channel (200mW/channel for DF111, 180mW/channel for DF410).
    If you are interested in further simplifying your design, I would consider a DS125DF1610. I suggest this device not only because it has sixteen channels so you would only require one device, but also because it has a 4x4 analog cross point switch for each quad, so it may allow you to eliminate the two DS100MB203’s in your design.
    Dan
