Part Number: TCA9406
Other Parts Discussed in Thread: TCA9517A
Hi there supporter,
We are making our company's standard design of I2C level shifter and we are studying the low threshold voltage MOSFET, DIODES's DMN2400UV-7 and TCA9406 as well.
And as I know there is a significant cost gap between the mentioned two solutions and the price of TCA9406 might be several times of MOSFET's pirce. So, we need to well know why TCA9406 is necessary.
And I know the main difference between them is TCA9406 has one-shot so the slew rate of rising edge can be improved and it means it can support higher data rate, compared to MOSFET.
However, as my investigating result, not too many devices required the transmitting speed over than I2C 400kHz (according to Philips's application note, AN97055, MOSFET still can support the data rate up to 400kHz). So, can you give me your point-of-view why we need to apply TCA9406 as I2C level shifter solution instead of discrete MOSFET?
Your kindly help will be appreciated.
S,P. Lin
