P82B96: P82B96 Repeater Configuration
Part Number: P82B96
Could you confirm that the P82B96 could be configured in daisy chain as indicated in attached diagram?
Sean
P82B96 DAISY CHAIN EXAMPLE.pdf
  • Hello Sean,
    Sorry for the delay in the response.  I don't see any pull-ups in your schematic.  The configuration should work assuming you have correct pull-ups.
    -Francis Houde
  • Hi Francis,
    Yes the pull ups are included just not shown for clarity. The reason I ask is that there is no illustration of this connection scheme in the datasheet other than a short statement on page 3, (second paragraph): "The Sx/Sy side of the P82B96 is intended for I2C logic voltage levels of I2C master and slave devices or Tx/Rx signals of a second P82B96, if required "...Which I assume indicates okay for daisy chain?
    Sean
