TPS65983: TPS65983 Application Question for Intel's Alpine Ridge'
Part Number: TPS65983
Hi Sir,
1. May I know bin file different about low region and full region via TPS65983 Application Customizer 2_12?
2. We require combine via Intel's Imaginarium2 tool, which bin file is right?
3. May I know how to firmware programming IC when Complet bin file
4. Currently power rail function OK on PCB board but only Alpine Ridge's 0.9V no output! This issue is no firmware programming IC?
65983_low.rar
  • Wen Yung,
    For Q1, please review Section:3.5 of document SLVUAQ6 and let me know if you need additional information. The low-region image shall be used w/ Imaginarium tool to generate a full-flash binary that can be programmed on the sFLASH.
    I'm not sure I understand Q3 and Q4 - Can you please provide more details on the issues/observation?
    Thanks & Regards,
    Praneet
  • Hi Sir,
    Thanks for your reply.
    Currently we programming IC.
    plugged TB3 cable , Alpine ridge 0.9V can output and TB3 system can automatic system execution, but can not find TB3 device.
    May I know we have other device can help us to debug?
