Part Number: DP83865
I built 5 proto-type PWAs using DP83865DVH.
I’m working on debugging of this PWA, and facing the following symptom.
I need your help to proceed with debugging.
Symptom:
DP83865 does not respond to the MDIO access from the MAC.
See the attached MDIO access. All PWA has the same symptom.
I tried to apply inverted MDC clock to the PHY, however the same symptom resulted.
Question:
What are the conditions does PHY have, to respond to MDIO access?
What are your suggestions/recommendations to proceed with DP83865 MDIO debugging?
What do you think?
Thank you.
Nakazawa
