SN65HVD72: Schematic explanation
Part Number: SN65HVD72
I am having difficulty understanding this RS485 implementation in RS485-pi. Can you please explain how tying RE and DE to the inverted TxD signal would work?
Rohit Joshi
  • Hi Rohit,
    This circuit basically makes it so the RS-485 transceiver has two states:
    - D signal low: driver is active and drives a negative differential voltage onto the bus (to be interpreted as a logic "low" level by an RS-485 receiver).
    - D signal high: driver is inactive (high impedance) and does not drive the bus.
    In the second state, the intention is for the undriven bus to be interpreted by a receiver as a logic high level. This can be accomplished by adding external resistors that add a weak positive differential bias to the bus (i.e., pull-up resistor on the A line and pull-down resistor on the B line). This could also be accomplished by using exclusively receivers that feature internal failsafe biasing (like the SN65HVD72). This feature offsets the receiver input thresholds in the negative direction, ensuring that a 0-V differential input is reliably interpreted as a "high" level.
    Note that while this scheme can work, it won't benefit from the large noise margin present in standard RS-485 links (in which the high and low states are both actively driven by the transceiver). If you want to retain this margin without adding a separate control line for the DE/RE enable inputs, then you can use a simple timer circuit to generate an enable pulse when the D pin toggles. For an example of this, please see the following reference design:
    www.ti.com/.../TIDA-01090
    The R/C components used in the 555 timer circuit can then be scaled based on the frame length and data rate required by the application.
    I hope this helps; please let me know if you have any other questions.
    Max
  • Hi Max,
    Thanks for that detailed explanation.
    Am I correct in assuming that this configuration is transmit only. Would that still be called half-duplex as the webpage claims?
    Rohit
  • Rohit,
    This would still be bi-directional/half-duplex; you would just need to be sure to keep the D line high when you want to receive data. (In this condition, the /RE and DE pins are low and data from the bus will be reflected on the R output pin.)
    Max
  • Okay, I think I got a handle on this.
    When D is high, this RS-485 will be in receive but if not other transceiver is actively transmitting, then all the receivers will read an active high as you have explained in your first response.
    Thanks for your help!
    Rohit
