Part Number: TMDS361B
Hi Team,
My customer uses I2C command to control TMDS361B, not S1, S2. And they want to know HPD switch time from I2C command send from EP.
1. Switch event timing on I2C
Figure 3 in this datasheet shows switch time from S1 and S2 transition. Which timing will be trigger of the Ch change when controling by I2C?
I expect to be either "Slave's ACK" or "STOP bit" but I'm not sure.
2. Max time of Ch switching by I2C
Figure 3 in this datasheet shows switch time from S1 and S2 transition but there are no timing data when controlling by I2C.
Don't you have Max time of Ch switching when I2C command is use for controlling?
Takashi Onawa
