DS90CR287, DS90CR288A Cam link Transmitter/Receiver
Other Parts Discussed in Thread: DS90CR288A, DS90CR287
In our Customize design we are using Camlink interface.  Our requirement is up to 80 MHZ . We have selected DS90CR287, DS90CR288A for this interface. Is it right choice ?
As in one of Post i have read that TI doesn't have any CameraLink transmitters or receivers.
With Regards
Neelam
  • Hi Neelam,
    The DS90CR287, DS90CR288A (28-bit) are reasonable selections based on the criteria provided. The temperature is -10C to 70C instead of -40C to 85C. The EVM CLINK3V28BT-85 can be used to evaluate the DS90CR287/288A's operation.
    Dennis
    Thanks for the response. We need Device in the Temperature range of -40 to 85 C . Can you please suggest in that Range that is alternative of DS90CR287, DS90CR288A.
    Could you please clear what is difference between Flat panel Link and Cam link as some where in forum it is mentioned that flat link chips may not suitable for Camlink applications.
    e2e.ti.com/.../563211
    Neelam
