TCA6507: SDA & SCL 5V tolerant?
Part Number: TCA6507
The product page states that the I/O is 5V Tolerant. But the recommended max voltage on SDA and SCL is 3.6V according to the datasheet. So I am a bit confused here.
Will it be OK to use a 3.3V supply and pull up the SDA and SCL lines to 5V?
Thanks and best Regards,
Frans Jan
  • Hi Frans,
    The 5V tolerant spec is specifically for outputs only, in this case the LED pins (pins P0-P6) NOT the SDA/SCL lines. The absolute max for Vcc is 4.6V and the optimal voltage for Vcc and SDA/SCL is 1.65V - 3.6V. The SDA and SCL lines should be connected to Vcc through a pull up resistor.
    Why are you wanting to pull the SDA/ SCL lines to 5V?
    Are you wanting to pull the SDA/SCL lines to 5V to interface with a 5V micro controller? If so you might want to use a buffer or level shifter.
    Daniel Noel
  • Hi Daniel,
    I wanted to connect the TCA6507 to a 5V I2C bus. But now I will use a level shifter.
    Thanks!
    Frans Jan
