SN65HVD251: How to implement the SPLIT pin
Part Number: SN65HVD251
Hi Team,
If am using the SN65HVD251 with the SPLIT termination setup, what do I do with the SPLIT pin? Where do I connect it to?
Thank you,
Jared
  • Hi Jared,
    Here's an illustration showing split termination:
    Connect the SPLIT output to the node circled in red.  This is an optional connection that helps to bias the recessive-state common mode more strongly towards VCC/2.
    Max
