TPS2066: About enable pins
Part Number: TPS2066
Could you tell me about TPS2066 EN pin?
The TPS2066 Enable pins (EN1 & EN2) are active high.
If I want to permanently enable the outputs I would pull these pins high to 5V.
In this case should I use a pull-up resistor i.e. 10kohm?
Could you give me your advice?
Yusuke /Japan Disty
