DP83867E: Question of IDLE ERROR COUNTER
Part Number: DP83867E
Hi team,
What does IDLE ERROR COUNTER (Address=0x000A[7:0]) in DP83867mean? Does the counter work when link is down?
-. Is it related to MDI issue (between RJ45 and PHY), or MII issue (between PHY and SoC)? Otherwise, both?
-. At a test for link down in MDI line, it seems that the error is not recognized. Is it normal behavior?
Sam Lee
  • Hi Sam,
    It is related to idle symbols on the MDI. The MDI needs to be connected to the link partner, and link must be active, before idle symbols are exchanged.
    When you disconnect a link, you should get burst of idle errors. The idle error count should be clear on read, but the DP83867 doesn't latch the count properly. A read immediately after the disconnect event should show idle errors.
