TCA6408A: About TCA6048A Application Question
Part Number: TCA6408A
Hi Team,
I have question about TCA6408A.
We find high current occur when ADDR pull VCC.   Output PIN always high.
When ADDR pull GND. current just 10mA? Right?
May I know how to let TAC6408 into standby mode? since our power source is Battery.
  • Hi Cao Cao,
    I would not expect much difference in current consumption between pulling ADDR high or low. How much current are you observing? Are you able to communicate with the device and reconfigure P[7:0] under both conditions?
    This device will be in a low-current standby state when SCL is not toggling. Under this condition, the current consumption is typically just 1 uA.
    Max
