SN65DP159: About I2C_EN/PIN
Part Number: SN65DP159
Hi all.
I have some questions about I2C_EN/PIN>
1.When I2C_EN/PIN is Low, when the device read from SLEW_CTL, PRE_SEL and EQ_SEL/A0.
    I would like to the time chart.
2.Can we change high or low of I2C_EN/PIN dynamically?
3.If we don't use SDA_SRC/SCL_SRC/SDA_SNK/SCL_SNK pis, can I open this pin?
I would like to get your comment as soon as possible/
Sho
  • Hi all.
    How about my question?
    Please let me know if you have any comments.
    My customer would like to get your answer as soon as possible.
    Sho
  • Hi Sho-san,
    1. Are you looking for the time it takes to
    2. You can change I2C_EN without having to assert a reset or do a power cycle.
    3. Tie to GND SCL_SRC/SDA_SRC, place 2k pull-ups to 5V in SCL_SNK/SDA_SNK.
  • Hi Moises san
    Thank you for your quick response.
    I commented to your answer the below.
    >>I understood that, these pins are sampled continuously, so I don't need the timing chart.
        Is it correct?
    >>I understood that we can change I2C_EN dynamically.
    >>It is ok about SCL_SRC/SDA_SRC.In additional to your advice,
        I think that the SCL_SNK/SDA pin should be connected to the DDC_SCL / DDC_SDA pin.
        Is it correct?
    Best REgards,
    Sho
  • Hi Sho-san,
    1. Yes, pins are sampled continuously, in GPIO mode you can verify the status of GPIO reading I2C registers.
    3. For DDC, we recommend snoop mode, this is SCL_SRC/SDA_SRC tied to GND, SCL_SNK/SDA_SNK are connected to SCL/SDA from HDMI connector to GPU plus 2k pull-ups to 5V. Having this snooping DP159 can monitor TMDS_CLK_RATIO and configure itself as needed.
    Some customer, don't want to use snoop mode and prefer to control TMDS_CLK_RATIO by I2C.
    If the GPU doesn't support 5V from DDC an extra level shifter will be needed.
