ULN2803A: Output is not inverted.
Part Number: ULN2803A
Make circuit as attached, but its output is not inverted. (see attached waveform)
Could you review attached schematic, and let me get the result?
Nicky
ULN2803_Sch.pdf
  • When the corresponding GRx input is high, you are pulling the GRID signal low. This implies that the other outputs often have a low voltage, either because the ULN drives the output low, or because the GRID signal is driven low.
    What actually matters is not the voltage, but whether a current flows. Try measuring if there is a voltage drop over the LEDs and their resistors, i.e., measure the voltage at the LED.
